rvf Posted January 23, 2012 Posted January 23, 2012 2003 RX300, 120,000 miles. Remote door lock/unlock buttons now operate only the rear passenger and rear hatch doors. Front doors must be opened manually with key (happened to passenger door, then driver door, about 2 months apart). Remote device batteries replaced. Fuses okay. Ideas on what the problem is / resolution ?
lenore Posted January 23, 2012 Posted January 23, 2012 your lock mechanisms in the front doors probably died. common problem on the RX300...involves changing the lock actuators....here is a long posting on how to fix them for yourself... http://www.clublexus...x-write-up.html here is a better one for the RX330 series of RX http://www.clublexus.com/forums/rx-second-generation/612350-rx330-door-lock-actuator-diy.html
jazzcat Posted January 24, 2012 Posted January 24, 2012 You may be parking in an area where the frequency is being disrupted. Does this happen every where?
