I just noticed this for the last couple of days (maybe weeks) when I start my RX330 the headlights do not come up, It used to before and light used to move up and down; now nothing happens. There is NO warning light on dash per manual.
The lights do turn on. I do not want to spend Arm and leg to get this fixed. Not sure if this a Fuse issue
Any help will be very much appreciated.
LN
You haven't shut the AFS off by chance? The switch is right above the fuel filler door button, and I know I've accidently hit the AFS button the odd time while trying to gas up.
Does your Rx330 have both the auto-leveling (up and down) and AFS (left and right as you turn around corners) features? Or just auto-leveling? There are several versions of headlights for this vehicle.
Are the headlights aimed at a normal level? Too high? Too low?
Are both headlights acting this way? Or just one and not the other?
The headlight beam is quite low; no more than 20-25 feet.
The AFS seems to be working fine; when I turn the steerting wheel in corners (night driving) - I can see the light focus move from left to right or rigjht to left.
Both light beams are low.
Thanks,
LN
