My_Rx330 Posted January 18, 2012 Share Posted January 18, 2012 I just noticed this for the last couple of days (maybe weeks) when I start my RX330 the headlights do not come up, It used to before and light used to move up and down; now nothing happens. There is NO warning light on dash per manual. The lights do turn on. I do not want to spend Arm and leg to get this fixed. Not sure if this a Fuse issue Any help will be very much appreciated. LN Quote Link to comment Share on other sites More sharing options...
lemon Posted January 22, 2012 Share Posted January 22, 2012 You haven't shut the AFS off by chance? The switch is right above the fuel filler door button, and I know I've accidently hit the AFS button the odd time while trying to gas up. Quote Link to comment Share on other sites More sharing options...
cduluk Posted January 25, 2012 Share Posted January 25, 2012 Does your Rx330 have both the auto-leveling (up and down) and AFS (left and right as you turn around corners) features? Or just auto-leveling? There are several versions of headlights for this vehicle. Are the headlights aimed at a normal level? Too high? Too low? Are both headlights acting this way? Or just one and not the other? Quote Link to comment Share on other sites More sharing options...
My_Rx330 Posted January 26, 2012 Author Share Posted January 26, 2012 The headlight beam is quite low; no more than 20-25 feet. The AFS seems to be working fine; when I turn the steerting wheel in corners (night driving) - I can see the light focus move from left to right or rigjht to left. Both light beams are low. Thanks, LN Quote Link to comment Share on other sites More sharing options...
