fire lexus Posted December 17, 2011 Share Posted December 17, 2011 dear all i have lexus GS300 2009 , last week while i was washing it by mistake i click and open the lid trunck twice , the frist one were open but when i cliked the second time a stange sound comming and auto closure mechanisume were not working , so i closed it manually , and i tryed to open it again it failed to open , just a sound from the transmiter and didnt open . any one can help me if he face this problem before. regards Quote Link to comment Share on other sites More sharing options...
fire lexus Posted January 1, 2012 Author Share Posted January 1, 2012 guys i had fixed it by disconnecting the battery and reconnect it for 12 min. but you have to reset the windows and the moon roof so if any one face this problem , now he had the solution regards Quote Link to comment Share on other sites More sharing options...
steviej Posted January 1, 2012 Share Posted January 1, 2012 the answer you seek lies in the reply to your post in a different thread: see below. good day guys i had similar problem , my one touch operation for the moon roof is working but not properly, this happened after i disconnect the battery and reconnect it. the first one touch operation should open the moon roof up to the half ,and the second will open it full , what is happening now the first touch open it up to 80% rather than 50% as it was before ,but the one touch closing is working properly and tilted as well any idea thanks You stated the reason yourself. It is because you diconnected the battery. Both the moonroof and power windows will have to be "normalized", in other words, they have relearn their respective programming. The instructions are clearly described in your owners manual and previously in this thread. Simply stated: Moonroof: push and hold the UP button unitl the moon roof tilts all the way up and then down a little automatically. Windows: 1. push down the power window switch for each window using the switch of each door so that the window goes halfway down. 2. then pull up the switch unitl the windows close and hold the switch for one second. steviej Quote Link to comment Share on other sites More sharing options...
