hansrobert Posted December 14, 2011 Posted December 14, 2011 I have a 2011 450h and it has a continously variable transmission. I was curious if anyone knows at what speed it achieves its most efficent ratio? Thanks!
lemon Posted December 15, 2011 Posted December 15, 2011 Isn't the idea behind a CVT is it always being in the most efficient ratio based on speed/load etc.?
hansrobert Posted December 15, 2011 Author Posted December 15, 2011 Isn't the idea behind a CVT is it always being in the most efficient ratio based on speed/load etc.? Yes it is but perhaps my question is not specific enough. What I would like to know is the speed at which my 450h will achieve the most efficient ratio. Thanks again!
katzjamr Posted December 15, 2011 Posted December 15, 2011 coasting at any speed would be the most efficient i would think.
jaswood Posted December 18, 2011 Posted December 18, 2011 Isn't the idea behind a CVT is it always being in the most efficient ratio based on speed/load etc.? Yes it is but perhaps my question is not specific enough. What I would like to know is the speed at which my 450h will achieve the most efficient ratio. Thanks again! Modern day gasoline engines have two high efficiency ranges, low, cruise, RPM wherein pumping losses are high but frictional losses are low. WOT with pumping losses zip and frictional losses high. The HSD control computer is constantly adjusting the CVT to minimize FE based on overall conditions. So there no good, exacting, answer to your question. Overall FE optimization, "cruise" optimization,...likely ~55MPH. 55MPH.
