psabbs Posted December 14, 2011 Posted December 14, 2011 I need ome help my maintenance required light stays on. I have reset all maintenance items on the Nav screen ie. Oil change, filter, etc but the light stays on. The manual says check with a dealer.
bainzey Posted December 14, 2011 Posted December 14, 2011 I need ome help my maintenance required light stays on. I have reset all maintenance items on the Nav screen ie. Oil change, filter, etc but the light stays on. The manual says check with a dealer. Turn your ignition on and set your odometer so that it is on the actual reading not a trip. Then: With the ignition off, hold down (push in) the trip reset button. Continue to hold it in as you start the car. I hold it in for about 10 seconds, you will see the odometer flash(reset has occurred) and then your light will be off.
psabbs Posted December 15, 2011 Author Posted December 15, 2011 Bainzey, thanks worked great, the light is now off.
