Safety Recall, Special Service Campaign (Ssc) And Limited Service Camp
lemon
If you frequent the RX hybrid forum, you'll see that I'm a bit of a TSB hound. I found some more today, but I also found a document titled "Safety Recall, Special Service Campaign (SSC) and Limited Service Campaign (LSC)General Procedures".
It's very interesting reading, and from what I can see, if your vehicle is subject to any of the above (recalls or campaigns), you're supposed to get at least your tank filled with gas. I'm not quite sure of the rental vehicle section, but it would seem you're entitled to a rental vehicle as well.
I believe this applies even if you're out of warranty, because a recall or campaign is not affected by whether the vehicle has warranty or not.
I know several people have had recalls recently done, and the free tank of gas seems to be hit and miss (the recent RX recall for the kick plate by the gas pedal comes to mind).
050847.PDF
050902.PDF
050916.PDF
050929.PDF
050943.PDF
050959.PDF
051015.PDF
051026.PDF
051040.PDF
