The factory chrome wheels are flaking and corroding badly enough that it's hard to keep the bead sealed, and even harder to keep wheel weights on. Evidently my LS430 came equipped with larger front calipers, and my local Tire Discounters has no idea which aftermarket wheels will fit. Two of the styles they showed as a correct fit would not clear the calipers on the front. I don't want to get 17" or 18" wheels, because the 16" tires I have are basically new.
So, anyone know of a subtle-styled 16" wheel that will fit over the large front calipers on an '02 LS430?
Thanks in advance,
Tom
Why not just purchase another set of OEM wheels? I found a number of them with a Google search that were priced about the same as most entry-level aftermarket ones. You might also find some at a salvage yard....this one where I live has a complete set from an 02 for a reasonable price. http://rich-industries.com/.
I believe wheels from a 98-00 LS 400 would also be a direct fit as I have seen 01-03 LS 430s with them installed and think they look quite good.
That's a good thought, although unless I can buy locally and see the condition of the wheel, I'd be suspect. Plus, if it doesn't fit for some reason, I'm stuck...
Cheers,
Tom
