dws Posted September 24, 2011 Share Posted September 24, 2011 Any suggestions or help removing the Y-Pipe Converter on my RX300...? The problem I have is on the end up in the engine compartment and it's tight with no clearance to get the 2 rusted nuts off the bolts. I have tried PB spray, but don't have a torch. I bought a whole new exhaust system from Walker Exhaust, and replaced everything except this Y-Pipe converter. Then there's a big pin hole in the old Y-Pipe that I had forgotten about. My next step is to take it to a garage and have them remove everything and torch the old Y-Pipe off, but I would rather do it myself. Thanks !!! Quote Link to comment Share on other sites More sharing options...
TGS1969 Posted January 24, 2012 Share Posted January 24, 2012 Any suggestions or help removing the Y-Pipe Converter on my RX300...? The problem I have is on the end up in the engine compartment and it's tight with no clearance to get the 2 rusted nuts off the bolts. I have tried PB spray, but don't have a torch. I bought a whole new exhaust system from Walker Exhaust, and replaced everything except this Y-Pipe converter. Then there's a big pin hole in the old Y-Pipe that I had forgotten about. My next step is to take it to a garage and have them remove everything and torch the old Y-Pipe off, but I would rather do it myself. Thanks !!! Have them heat up the bolts and then bang on the Ypipe to break the rust free around/underneath the bolt heads, douse with PB and remove them. Otherwise they'll need to be melted off with ye old torchomatic :) Quote Link to comment Share on other sites More sharing options...
janepaul Posted March 17, 2012 Share Posted March 17, 2012 even my friend has the same problem thanks for your suggestion it would help a lot... Quote Link to comment Share on other sites More sharing options...
