Hello All!!
I'm new to the board but so happy to know there's something like this available.. I have a 06 GS 300 and I currently have a warning message stating, "Check VSC"...??? when I looked at some of the posts on the board they said this usually means the gas cap needs to be replaced.. Well, I replaced it but the warning message is still on...
Have any of you experienced this..?
A loose or defective gas cap is one of many issues that can cause a Check VSC warning. It's as if the Check VSC warning comes on just to get our attention when darned near anything goes wrong. I've had a Check VSC message on my 00 LS when the PPS/TPS started to fail, when a battery has begun to fail and even when battery posts needed cleaning. If the battery condition is good, you might as well take it to somebody who can see if there are any stored problem codes. Guessing can get expensive.
