sadc Posted September 8, 2011 Share Posted September 8, 2011 So on my way to work, I slowed to into the main entrance of my working place(maybe 3-5MPH.) As I slowed down my car died. Tried to start it again, it never fired. Cranks but no start. So pushed it into a stall. I thought my fuel pump died since my car does have 219,xxx miles on it. So I sprayed starter fluid into the intake manifold through the throttle body. Still a no start. What could be the issue? About 3-4 days ago I cleaned my throttle body and my EGR(the one thats located next to the throttle body sensor) What else should I check for? I also checked for spark and yes I still do have spark. I also took out the AFM to see if it would start without it on but still would crank but no start. Im at a loss Thanks for reading Specs on the car is: 1992 lexus es300 5 speed spark plug changed 100 miles ago Timing belt water pump pullys changed 200 miles ago Throttle body, EGR cleaned 20 miles ago. Also I unplugged the battery just in case. Still a crank but no start. I Also pulled a code by jumping TE1 and E1 and I got code 24. Will this cause my car to crack but no start? Quote Link to comment Share on other sites More sharing options...
