Crusier Posted August 14, 2011 Share Posted August 14, 2011 Do anyone know how to remove the door panel driver side of a 2000 Lexus GS400? Quote Link to comment Share on other sites More sharing options...
lexmaniac00 Posted August 16, 2011 Share Posted August 16, 2011 Cruiser, Here is the procedure for removing the driver side door panel in a GS400: **Diagrams** GS400 driver door panel diagram 1. Remove the door inside handle bezel cover. 2. Remove the door trim. 3. Remove the screws. 4. Insert a screwdriver between the door panel and door trim to pry it out. 5. Pull the trim upward to remove it, then disconnect the courtesy light connector. 6. Remove the courtesy light from the door trim. 7. Remove the 2 cables from the door inside handle. To install, reverse the removal procedure. Quote Link to comment Share on other sites More sharing options...
