HOW DO I REMOVE THE LENS FROM A FRONT SIDE MARKER LIGHT ON A 2001 RX300? DO I USE A SCREW DRIVER TO PRY IT OFF FROM UNDERNEATH?
THANK YOU
TOMB
Is the lamp in the attached diagram what you are referring to? The lamp assembly looks very much like the ones on my 00 LS400 which are removed from behind by removing a couple of fasteners holding the front of the wheel well liner in place and then and reaching behind the bumper cover to remove the bulb socket and then the nuts or screws holding the assembly to the bumper cover.
The diagram is from http://lexus.sewellparts.com/
post-2157-0-44461100-1312731203_thumb.jp
