DIY31 Posted July 16, 2011 Share Posted July 16, 2011 I want to change my ATF and Filter. With the changes in fluid over there years can you anybody recommend the right fluid. Also what brand filter and gasket do you recommend? And last. Is there any tricks or additions I should know about before I start this project? LS400 1995. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted July 16, 2011 Share Posted July 16, 2011 If you searched on this subject it has been discussed many times and the answer is always to use only Toyota Type IV transmission fluid. With the filter and gasket sets OEM is your best bet although aftermarket ones are available. If you look at the tutorials on www.lexls.com there is information on there regarding fluid and filter changes for the earlier LS400s but the later model is similar so it makes a good guide. Quote Link to comment Share on other sites More sharing options...
