Enola Straight Posted June 21, 2011 Share Posted June 21, 2011 Lately I've had the two idiot lights come on, but haven't got the time to go pull any codes. Using search, I figure the problem is either bad oxygen sensors or a charcoal canister issue. Ideas? Quote Link to comment Share on other sites More sharing options...
omee Posted June 25, 2011 Share Posted June 25, 2011 I had the same 2 lights on, It turned out to be the after cat o2 sensor. From what I gather, the computer turns off trac control when the check engine light comes on. might be something else, better pull the codes to be sure -Omar Quote Link to comment Share on other sites More sharing options...
Berry B Posted June 27, 2011 Share Posted June 27, 2011 i actually pulled my codes and these are the ones that came up P0171-LEAN BURN B1 P0125 – INSUFFICIENT COOLANT TEMP P1135 – AIR/FUEL RATIO SENSOR HEATER CIRCUIT B1S1 P1354-VVT FAULT B2 (VARIABLE VALVE TIMING SOLENOID) but the only problem i ran into was no one could tell me what code p1354 was or what actually to replace im geting everything fixed today so i will let you kno if the Check ENG light and TRac off light goes off this is my email llbear27@gmail.com email me Quote Link to comment Share on other sites More sharing options...
mlgbwk Posted June 29, 2011 Share Posted June 29, 2011 I got both lights on twice: first time it turns out cat converter went bad, I did not bother to fix and simply use a $3 resistor to trick the computer and the light went off 2nd time it is P1135, if i remember it correctly i bought it for $100 from amazon and installed it, it was a pain to remove the old one though. i actually pulled my codes and these are the ones that came up P0171-LEAN BURN B1 P0125 – INSUFFICIENT COOLANT TEMP P1135 – AIR/FUEL RATIO SENSOR HEATER CIRCUIT B1S1 P1354-VVT FAULT B2 (VARIABLE VALVE TIMING SOLENOID) but the only problem i ran into was no one could tell me what code p1354 was or what actually to replace im geting everything fixed today so i will let you kno if the Check ENG light and TRac off light goes off this is my email llbear27@gmail.com email me Quote Link to comment Share on other sites More sharing options...
