tomb57 Posted June 2, 2011 Share Posted June 2, 2011 I have a sensor of some type not connected to the engine. It is one wire (white w/red stripe), grey connector, and a mounting plate. I suspect it should be bolted to the upper motor mount next to the timing belt cover and the upper radiator hose casting. Can anyone confirm this, and what is it, and what does it do? They must of not remounted it when the timing belt was changed. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
