Rx400H Vsc Resent
i got a 06 rx400h i changed the brake fluid and ran it on the rack now my vsc light abs light are on i tried clearing with wire and wont clear please help !!!!!!!!!
The brake system has to be bled. Apparently only the Lexus dealer can do this as the service computer must be hooked up via the OBDII port and the computer is then used to cycle the motors that provide brake pressure. Since there is no traditional brake booster (as in a non hybrid vehicle) you can't simply pump the brake pedal when bleeding the system. If you changed the fluid, you need to properly bleed the system.
