Problem With 93 Lexus Es 300
Ok first want to know is there anyway to raise my shocks on my back tires
Another problem is my rpm gauge no long workers but speedometer works
Also where do I bu the plastic clips that hold my panels up inside the car I also have a few missing in the trunk. I hope somebody can help me
Hi,
Sounds like you should replace rear struts, unless you want it to be a higher than usual ride, then I'm useless.
I'm not exactly sure how the tach gets signals but I bet it's from the computer. May just be a bad wire or connector. The other prob may be that you need a new tach, and I'd get a used cluster from the yanker yard, once you check on the line continuity.
Plastic clips can be had at a yanker yard too, or most auto stores and hardware stores carry many different types of clips.
LL
