Zdeno Posted February 22, 2004 Posted February 22, 2004 hi, I just bought Trany mount from dealer and I don´t have to find where the mount is. I have repair manual, but there is nothing about how to exchange it. Can somebody help ?
jzz30 Posted February 22, 2004 Posted February 22, 2004 it helps if you have a ramp but well get the front of the car high enough so that you can crawl under it then jack up the trans a bit to take the load off of the mount. there should be a brace between the trans take the 4 bolts off then the brace comes off oh and the 4nuts? that are attatched to that is the mount to the brace( i know this sounds confusing) then it should just be another 4 bolts to take the mount off. good luck oh use a small piece of wood between the jack and the trans.
Zdeno Posted February 22, 2004 Author Posted February 22, 2004 So it is almost same like I did on my other car (volvo 740). I was afraid when I saw the mount that it could be on other place, but it will be same. Thanks again
