Trany Mount - Where Is It ?
Zdeno
it helps if you have a ramp but well get the front of the car high enough so that you can crawl under it then jack up the trans a bit to take the load off of the mount. there should be a brace between the trans take the 4 bolts off then the brace comes off oh and the 4nuts? that are attatched to that is the mount to the brace( i know this sounds confusing) then it should just be another 4 bolts to take the mount off. good luck oh use a small piece of wood between the jack and the trans.
