Help!
My Lexus RX300 has no reverse at the a/t transmission.
Indicator at the dash is not showing green sign on P and R.
It is only showing green on N,D,2,L
but car is still going forward even though It is in R and N !
What is wrong ?
any advice is much appreciated.
It is a 1MZ-FE 2 wheel drive.
MCU10W model
Sounds like the shift actuator on the tranny,,,it is located below the battery on the front side of the transmission..maybe it has failed or loose or misadjusted..
i tried playing with it by removing the shift cable and tried dismantle it too.
I cant see any defect inside. I cleaned the contacts inside and still make no difference :(
Any advise ?
there is a precise adjustment for that assembly...Sorry cant remember it.
  • 10 years later...
I have a 1999 Rx300. I have been told that my transmission has busted, then I have also been told that it could be a few simple things to fix it. Either way, it WILL NOT free roll in any gear or neutral. Will not move in reverse. Thinks about moving in drive. Its an AWD which throws in more possible problems than the 2WD. Any advice?
