Window
If something is causing too much friction or impeding the movement of the glass, maybe the "pinch protection" feature is kicking in and preventing the window from opening. Maybe remove the door panel and take a look?
The driver's side window on my '02 LS 430 is failing to open all of the time. The sill is trying to expand, indicating the glass plus
the tint app may be expanding. Should I be thinking replacement of the motor?
My guess (take it for that) is the window switch. A high resistance spot on the contacts will supply some current to the motor...enough to cause it to attempt movement but not enough to get the motor really going. Sometimes it works, sometimes not. Characteristic of worn or dirty switch contacts.
