Heavymental Posted March 24, 2011 Share Posted March 24, 2011 my dome light, courtesy lights over brake pedal and ignition key ring wont light up when i open the doors. The door open indicator on the dash works. The dome light turns on when the switch is turned manually to the ON position. its a 95 LS400. all fuses look good. Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted March 24, 2011 Share Posted March 24, 2011 Fuses...are the only thing that I could think of? If you checked them all...I don't know? Did they all go out at the same time? Quote Link to comment Share on other sites More sharing options...
jaswood Posted March 25, 2011 Share Posted March 25, 2011 my dome light, courtesy lights over brake pedal and ignition key ring wont light up when i open the doors. The door open indicator on the dash works. The dome light turns on when the switch is turned manually to the ON position. its a 95 LS400. all fuses look good. "Fade" power transistor is open. Quote Link to comment Share on other sites More sharing options...
Heavymental Posted March 26, 2011 Author Share Posted March 26, 2011 youre talking about the switch thats located in the door? Quote Link to comment Share on other sites More sharing options...
