bill88 Posted March 1, 2011 Posted March 1, 2011 2004 w/ 118k miles, recently had the timing belt replaced (water pump, radiator, spark plugs) now the tach will sit at a base line showing 800 rpm when engine is off. Once running,the rpm will consistently reflect the extra 800 rpm. This is intermittent so I can't determine any other coincidental findings (electrical load etc). Any ideas? When the tach baseline is 0 it works correctly but can revert to the error while driving.
CaptnPete Posted March 4, 2011 Posted March 4, 2011 I had my speedometer fail at 42K and I removed the whole instrument panel. There I learned that the speedometer and tachometer needles are driven by two tiny motors. Mine had failed and I ultimately had to have the whole panel replaced. ($700+). You might try to remove the panel and access the unit from the back. Since the motor is working, perhaps you might give the needle a little nudge and get it back into the zero position. Pete
