PNUT27 Posted February 18, 2011 Posted February 18, 2011 TAIL LIGHT WARNING LIGHT CAME ON . I CHANGE THE BULBS THE WARNING LIGHT WENT OUT BUT THE LIGHTS STILL DIDN'T COME ON . SO I CHECK THE FUSE IT WAS GOOD BUT I CHANGE IT ANY WAY BUT LIGHTS STILL DIDN'T COME ON . ANYONE HAD THIS PROBLEM BEFORE PLEASE HELP ?
jainla Posted February 18, 2011 Posted February 18, 2011 Check the center mount stoplight (on top of the parcel shelf). TAIL LIGHT WARNING LIGHT CAME ON . I CHANGE THE BULBS THE WARNING LIGHT WENT OUT BUT THE LIGHTS STILL DIDN'T COME ON . SO I CHECK THE FUSE IT WAS GOOD BUT I CHANGE IT ANY WAY BUT LIGHTS STILL DIDN'T COME ON . ANYONE HAD THIS PROBLEM BEFORE PLEASE HELP ?
PNUT27 Posted February 18, 2011 Author Posted February 18, 2011 Check the center mount stoplight (on top of the parcel shelf). TAIL LIGHT WARNING LIGHT CAME ON . I CHANGE THE BULBS THE WARNING LIGHT WENT OUT BUT THE LIGHTS STILL DIDN'T COME ON . SO I CHECK THE FUSE IT WAS GOOD BUT I CHANGE IT ANY WAY BUT LIGHTS STILL DIDN'T COME ON . ANYONE HAD THIS PROBLEM BEFORE PLEASE HELP ? That light is not out thanks for your help
landar Posted February 18, 2011 Posted February 18, 2011 TAIL LIGHT WARNING LIGHT CAME ON . I CHANGE THE BULBS THE WARNING LIGHT WENT OUT BUT THE LIGHTS STILL DIDN'T COME ON . SO I CHECK THE FUSE IT WAS GOOD BUT I CHANGE IT ANY WAY BUT LIGHTS STILL DIDN'T COME ON . ANYONE HAD THIS PROBLEM BEFORE PLEASE HELP ? That is rather peculiar. So, you put new bulbs in, the warning light goes out but the new bulbs do not light? You are obviously drawing enough current with the new bulbs to satisfy the warning light. I would experiment and pull the new bulb(s) to see if the warning would come back on. Which bulbs did you replace and what brand/type did you use?
PNUT27 Posted February 19, 2011 Author Posted February 19, 2011 TAIL LIGHT WARNING LIGHT CAME ON . I CHANGE THE BULBS THE WARNING LIGHT WENT OUT BUT THE LIGHTS STILL DIDN'T COME ON . SO I CHECK THE FUSE IT WAS GOOD BUT I CHANGE IT ANY WAY BUT LIGHTS STILL DIDN'T COME ON . ANYONE HAD THIS PROBLEM BEFORE PLEASE HELP ? That is rather peculiar. So, you put new bulbs in, the warning light goes out but the new bulbs do not light? You are obviously drawing enough current with the new bulbs to satisfy the warning light. I would experiment and pull the new bulb(s) to see if the warning would come back on. Which bulbs did you replace and what brand/type did you use? I took the bulbs out in the warning light came back on. Put them back in the warning went back out i replace the brake lights and i used sylvania .
