tofu Posted February 16, 2011 Share Posted February 16, 2011 Hi all, Yesterday I washed my engine with the engine still running and drove it around for few miles and no problems. This morning driving to work and the CEL came on flashing and the car sound like miss firing. Pull the code and came up P0307,P0100,P0110. P0307 is #7 miss fire, P0100 and P0110 is AMF fault. I am thinking open the distributor cap and blow dry it but not sure which one is which and how hard to take it off. Thanx. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted February 17, 2011 Share Posted February 17, 2011 Plugs # 1,4,6,7 are fed from the driver's side (RHS looking into the engine bay) distributor getting to it is not a five minute job see link below http://www.lexls.com/tutorials/ignition/distributor_rotor.html When you say AMF do you mean AFM Air Flow Meter? If so all you can do is try and dry it out with a hairdryer both externally and internally by removing the air ducting and aiming inside. Quote Link to comment Share on other sites More sharing options...
tofu Posted February 18, 2011 Author Share Posted February 18, 2011 Yeah, I found water inside plug #7 housing, cleaned it up and car is running good now. Thanx. Quote Link to comment Share on other sites More sharing options...
