Hey I'm trying to take out both of the tail light lenses off so I can spray tint them. Any help on how to get them off? Thanks.
-Sully
I would imagine the 430 is similar to the 400 and it involves removing the trim behind the clusters in the trunk and trunk lid,you should then be able to see and remove the securing nuts to remove the clusters.
Do you want to literally take the "lenses" off of the units? You don't need to remove the lenses, just mask off the surrounding areas (once you have the lights removed from the car).
