kuziwk Posted January 25, 2011 Share Posted January 25, 2011 So when im braking and the transmission dowshifts sometimes the car will clunk a bit i pretty much only notice it on smooth roads, the car shifts up fine maybe not as smooth as it should be but i think its part of the throttle position adujustment under the trac cover, because i cant find the proper adjustment i guess. At any rate putting on the ect switch for a bit seems to help. I cleaned the pan, changed the filter and oil 10 000 miles ago, could this be a bad speed sensor? Dirty throttle body? maybe shift solenoids?, i dont know. Quote Link to comment Share on other sites More sharing options...
curiousB Posted January 25, 2011 Share Posted January 25, 2011 Loose or worn u-joints on drive axle? Quote Link to comment Share on other sites More sharing options...
billydpowell Posted January 25, 2011 Share Posted January 25, 2011 Loose or worn u-joints on drive axle? might want to check the tranny mount too..... Quote Link to comment Share on other sites More sharing options...
kuziwk Posted January 26, 2011 Author Share Posted January 26, 2011 Loose or worn u-joints on drive axle? might want to check the tranny mount too..... Hmm i already changed the mount, i know the engine mounts are due though. It's weird it's shifting perfect from leaving in it ect all day and driving more aggressively due to the roads melting a bit (clear out the carbon a bit, lol). Quote Link to comment Share on other sites More sharing options...
billydpowell Posted January 26, 2011 Share Posted January 26, 2011 I changed my tranny & engine mounts at about 160k on one of my 99's, and they came out in pieces, but I had no "sound/clunk" in mine, just some vibration I wanted to get rid of. and did. Quote Link to comment Share on other sites More sharing options...
