Right Front Passenger Window Stuck
rx49er
Have 2000 RX300 with right front passenger window stuck in down position. Able to take door panel off and use motor with leverage to close window. Cleaned window but still has problem getting stuck when in down position. Current solution is to keep closed. It appears the motor works as the window does open and close intermittently. Not sure why window gets stuck in down postion. Other windows working fine. Any ideas?
  • 2 months later...
Are you having a problem opening the window from the passenger door OR from the driver's master control keys?
  • 5 months later...
BUMP... I'm having the same problem. My passenger door window gets stuck when lowered. It doesn't respond using both the passenger doors switch OR the drivers master control keys.
