Has anyone figured out how to access the rear wiper so the blade can be replaced? The owner's manual appears mute on this subject.
You shoulds be able to turn on the rear wiper then when it makes a swipe and is out from under the rear spoiler turn off the car and the wiper arm should be a position that will allow you to replace the blade insert.
True, but I suspect the brainiacs at Lexus have a better solution.
