wondering if anyone can tell me how to remove wheel well cover on 2000 Rx300 so that I can access windshield washer reservoir for rep.air & remove headlight assembly for cleaning. I've looked at wheel well liner, and it seems to extend under bumper with a rigid plastic that prevents me from pulling it aside.I've seen strings regarding other Lexus models that say to just pull it aside. Are the liners so different on other models, or should I just pull harder?
The Body Mechanical document at the following link should be helpful:
http://www.box.net/shared/o55c5697lt
If you download it you will be able to use search terms to locate your area of interest.
Alternatively, you can try the 1999 RX300 Repair Manual at the following link (Note: It will start downloading as soon as you click the link):
http://www.red928.com/Lexus/Lexus_-_RX-300_Repair_Manual_1999.pdf
It may take a while to download since it is a 25.5MB document. Good luck!
joe;
thanx for links, but they don't give answer to my question. I'll just have to try dis-assembleng the whole thing so I don't damage anything
