pondfisher Posted October 29, 2010 Share Posted October 29, 2010 Can someone post the procedure for replacing the low beam HID headlamp bulbs on a 98 LS400? Thanks in advance!! Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted October 30, 2010 Share Posted October 30, 2010 The procedure has been posted numerous times in the past since it is essentually the same on all model years of the LS400. Remove the light housing next to the headlight (which is the turn signal on the 98-00 LS400). Remove the bolts/screws that hold the headlight housing to the body and pull it forward to remove it from the car. Disconnect the power wire from the bulb, replace the bulb, reattach the power wire, and reinstall the headlight housing and turn signal housing. All this should take maybe 5 to 10 minutes. Quote Link to comment Share on other sites More sharing options...
