Newb With Power Seat Problems
Hi Everyone
I am new to this forum. I have a 1998 GS400 that I just bought, and the driver's seat has no power. Every option to move on the power seat is not working, even the lumbar support. It seem like a fuse was blown, but the fuse was fine. the harness connector looks fine too. To make matters worse, the seat is all the way forward so I cant drive it. Any help would be appreciate, also is there any way to manually adjust it back temporally.
Thanks
If you look along the top of the wiring diagram you will see (6) fuses related to the power seat. Some of them are located in the driver's side and/or passenger's side footwell kick-panel fusebox. Also there is a 7th. fuse, (P FR DOOR, 20A). Check them all. Otherwise, you'll have to do some testing to see if there is power at the various related modules.
Power_Seat_Diagram.pdf
