hey guys, im thinking of moving from the 17 inch oem rims to the bigger ones, possibly oem 18 inch ones. does any1 know the offset and tire size for the 18 inch rim?
Hi,
It looks like the OEM Lexus rims are 18x7.5J Offset is 45 tires are 225/40/18.
You would really need to put your present tire size into one of the tire size calculator websites to see if the rolling radius is correct with the above rim/tire combination.
I run the OE 18" wheel on my LS400 but with a 245/40-18, a little more sidewall is nice to cushion the wheels from potholes, etc. The change is size won't effect the speedometer enough to worry about.
