godpossessed Posted October 7, 2010 Share Posted October 7, 2010 I am getting the starter replaced today. It has been grinding for 2 years now upon engagement. What other items should be addressed while the intake is off for the starter work? thanks Mark Quote Link to comment Share on other sites More sharing options...
curiousB Posted October 7, 2010 Share Posted October 7, 2010 Make sure it has a new solenoid with it (specifically the contactor plate and contact points). That tends to go faster than the motor itself. Given it's major surgery to replace it you don't want to be going in again because they skimped by using the old solenoid. Use new gaskets on intake manifold too. Not a good idea to reuse old ones as you'll have vacuum leaks which create erratic engine running. Quote Link to comment Share on other sites More sharing options...
godpossessed Posted October 7, 2010 Author Share Posted October 7, 2010 Make sure it has a new solenoid with it (specifically the contactor plate and contact points). That tends to go faster than the motor itself. Given it's major surgery to replace it you don't want to be going in again because they skimped by using the old solenoid. Use new gaskets on intake manifold too. Not a good idea to reuse old ones as you'll have vacuum leaks which create erratic engine running. thanks mucho Quote Link to comment Share on other sites More sharing options...
landar Posted October 7, 2010 Share Posted October 7, 2010 Mark, You will want new gasket material for the manifold and perhaps some new rubber hose for any vacuum-type lines that may have become brittle with age/heat. I guess you could clean the throttle body while you have it somewhat exposed. And you might want to pull the valve covers and check the valve clearances if (and only if) you have been hearing excessive tappet noise. So, can you describe this starter grinding noise in more detail? Maybe starter bearings are excessively noisy? Quote Link to comment Share on other sites More sharing options...
AndyLowe Posted October 8, 2010 Share Posted October 8, 2010 Please see this link. It's currently on page 8 of this Forum and has been buried with time but is most helpful. Make sure you look at the photos. Andy http://us.lexusownersclub.com/forums/index.php?showtopic=64793 Quote Link to comment Share on other sites More sharing options...
