rfrodolfo Posted October 2, 2010 Share Posted October 2, 2010 I have a problem with my ES300, it was fine a couple of days ago, last night the transmission slipped, i parked and turned off the car, turned back on and it seemed fine, this morning, I drove to work, then back home and when i tried to drive again in the afternoon the car stopped completely in the middle of the road. It had just enough force left to get it off the road. i had it towed on a flat bed to the mechanic, and when i got there, the car did go forward on D and R (weird), after a while it didn't do anything else and was stuck again. a friend tells me it might be the transmission fluid, but it seems to fine, please help! Thank you! Quote Link to comment Share on other sites More sharing options...
Vinodh Posted October 2, 2010 Share Posted October 2, 2010 I had the exact same problem a couple of months back. I took it to 'Royal Transmission' and they said I have to rebuild the transmission :(. I think the clutch is slipping which is why the gear is not getting engaged. If you have a good mechanic friend who can rebuild the transmission, that is the only solution I can imagine. Sorry it happened to you. Mine was U140E type of transmission (can be seen in the label from driver's door) So I was given a quote of 2500$ to replace with a transmission from another car. There is another type which is little less expensive than this. Don't accelerate the car too much it will burn the inside of transmission. Quote Link to comment Share on other sites More sharing options...
rfrodolfo Posted October 4, 2010 Author Share Posted October 4, 2010 I had the exact same problem a couple of months back. I took it to 'Royal Transmission' and they said I have to rebuild the transmission :(. I think the clutch is slipping which is why the gear is not getting engaged. If you have a good mechanic friend who can rebuild the transmission, that is the only solution I can imagine. Sorry it happened to you. Mine was U140E type of transmission (can be seen in the label from driver's door) So I was given a quote of 2500$ to replace with a transmission from another car. There is another type which is little less expensive than this. Don't accelerate the car too much it will burn the inside of transmission. Thanks man, i appreciate you answering my question. Actually, what I am trying to do now is to get a transmission from ebay; they sell some cheap ones for like $300 plus shipping, and with 6 months warrant on it, so I might just need someone to install it. I was actually about to sell the car when this happen, I love the car, its in great condition, interior, exterior, engine good, and now this. oh well, I will try to get it done somehow. Another option that someone told me is that maybe can be a computer chip or the transmission fluid; I believe the guys from the transmission stores might just be trying to get our money, becuase the guy I took it to he said that he would charge me 400 just to take the transmission down and take a look at it, I feel he was beign dishonest becuase when I refused to leave it at the shop he began to get kinda upset and told me that if I find a cheaper way to fix it it might just be temporary which leads me to believe that taking the trans down and doing all that work might not be the only option to fix this, but we will see. Thanks again for replying man and good luck :) Quote Link to comment Share on other sites More sharing options...
Ray Garlington Posted October 7, 2010 Share Posted October 7, 2010 I have a problem with my ES300, it was fine a couple of days ago, last night the transmission slipped, i parked and turned off the car, turned back on and it seemed fine, this morning, I drove to work, then back home and when i tried to drive again in the afternoon the car stopped completely in the middle of the road. It had just enough force left to get it off the road. i had it towed on a flat bed to the mechanic, and when i got there, the car did go forward on D and R (weird), after a while it didn't do anything else and was stuck again. a friend tells me it might be the transmission fluid, but it seems to fine, please help! Thank you! Be sure to check the electronics associated with the transmission. A sudden failure like you are describing is often a sign that an electronic device/controller has failed. Based on your description it is a failure that the OBD system can not detect. Quote Link to comment Share on other sites More sharing options...
rfrodolfo Posted October 8, 2010 Author Share Posted October 8, 2010 I have a problem with my ES300, it was fine a couple of days ago, last night the transmission slipped, i parked and turned off the car, turned back on and it seemed fine, this morning, I drove to work, then back home and when i tried to drive again in the afternoon the car stopped completely in the middle of the road. It had just enough force left to get it off the road. i had it towed on a flat bed to the mechanic, and when i got there, the car did go forward on D and R (weird), after a while it didn't do anything else and was stuck again. a friend tells me it might be the transmission fluid, but it seems to fine, please help! Thank you! Be sure to check the electronics associated with the transmission. A sudden failure like you are describing is often a sign that an electronic device/controller has failed. Based on your description it is a failure that the OBD system can not detect. Thank you for replying, i appreciate all your help guys. Mr Ray, do you know by any chance what i have to check in specific regarding the electronic components for the transmission? i have tried to look information about it but have not been able to ind something in specific. Once again, thank you for your help. :) Quote Link to comment Share on other sites More sharing options...
Ray Garlington Posted October 8, 2010 Share Posted October 8, 2010 ... Thank you for replying, i appreciate all your help guys. Mr Ray, do you know by any chance what i have to check in specific regarding the electronic components for the transmission? i have tried to look information about it but have not been able to ind something in specific. Once again, thank you for your help. :) I do not have experience specific to this car, so in general terms any control module, solenoid or sensor involved with controlling the transmission can cause drive-ability problems. I have seen transmission control modules fail resulting in very unusual shifting without triggering an OBD. There are also solenoids and electronic sensors that can fail and cause similar problems. When the problem occurs, make careful note of all indications at the instrument cluster together with specifics about what the transmission is doing. Then see what Mr Google has to say. I have seen examples where a person will take the advice of a transmission specialist and have a rebuild done and in the end have the same problem they started with (because the transmission control electronics were faulty, not the mechanicals of the transmission). Quote Link to comment Share on other sites More sharing options...
JESSE CORTEZ Posted November 15, 2010 Share Posted November 15, 2010 I got same problem, car got caught in flash flood.. water over seats inside.. next week after it dried up, transmission started to act up. I ll turn key off and than restart and car will drice one or two block, than quits. wont move in drive or reverse. turn off key restart annd it will go again.take me thirt minutes to go to grocery stor six blocks away, but i aiant walking. what electronics are we talking about, i know there is a selonide insde transmissin, but no water got into transmission, also my built in phone quit, also radioquite. anybody please Quote Link to comment Share on other sites More sharing options...
