97 Ls Motor Mounts
turboomni
Are there any good aftermarket motor mounts made for these cars or is this a no no and stick with stock? I know Moog I think makes them. Also how difficult is it to do ? Any tutorials etc? I did do a search here and din't find much.'
My steering wheel and shifter have a slight vibration at idle in gear and I was told that bad motor mounts can ruin the EGR tube. I just had the tube replaced and dont want it to crack!!! I don't understand this either ,could some one explain this?
Wow Billy they are/were toast. What were your symptoms that you replaced them? Did you do the tranny mount as well? I checked the place you mentioned and they sell 2 motor mounts plus the tranny mount for 150 bucks. Sounds like a good deal if you were happy with them. At lexus [sewell] they were 319.00 a pair!! How is the install,,very difficult??
Thanks Billy
Thanks Billy
I had already done the tranny. I had no symptoms, but I knew they were bad. I am 76, so my nephew put them in, 3 hours. he said the drivers side was hardest. 150 for all is good. I might go ahead and order a set for my other 99.
