mikek753 Posted September 13, 2010 Posted September 13, 2010 Hi all, My key casings plastic got cracked and I can't use the key any more. I found that there is even Lexus specific TSIB BO005-06 for this matter that said about "bad" plastic used and have to be replaced by better one. However, my car 2004 is out of 4 years warranty to be covered. And I got quote from local Lexus service for this key casing as $80.00 !!! Is that quoter size plastic so expensive? Or something so special to it? Any idea where I can get this plastic cover for less? Otherwise as last resort I see to use epoxy to be able continue use ignition key.
LEXIRX330 Posted September 14, 2010 Posted September 14, 2010 Hi all, My key casings plastic got cracked and I can't use the key any more. I found that there is even Lexus specific TSIB BO005-06 for this matter that said about "bad" plastic used and have to be replaced by better one. However, my car 2004 is out of 4 years warranty to be covered. And I got quote from local Lexus service for this key casing as $80.00 !!! Is that quoter size plastic so expensive? Or something so special to it? Any idea where I can get this plastic cover for less? Otherwise as last resort I see to use epoxy to be able continue use ignition key. Do a search for this on here. A member on here has some good info on the eBay keys good ones and bad ones. http://us.lexusownersclub.com/forums/index.php?showuser=83491
mikek753 Posted September 14, 2010 Author Posted September 14, 2010 Do a search for this on here. A member on here has some good info on the eBay keys good ones and bad ones. http://us.lexusownersclub.com/forums/index.php?showuser=83491 looks like 1010keys at ebay could be my way to go ...
LEXIRX330 Posted September 14, 2010 Posted September 14, 2010 Do a search for this on here. A member on here has some good info on the eBay keys good ones and bad ones. http://us.lexusownersclub.com/forums/index.php?showuser=83491 looks like 1010keys at ebay could be my way to go ... Cool. Good luck with it!
