tofu Posted September 1, 2010 Share Posted September 1, 2010 Does anyone has a picture to show the location of the ECU for 2000 RX300? I need to remove the ECU so locksmith can program my new key, I only got valet key and it would save me $60 if I remove the ECU myself. Thanx. Quote Link to comment Share on other sites More sharing options...
joe913 Posted September 1, 2010 Share Posted September 1, 2010 Does anyone has a picture to show the location of the ECU for 2000 RX300? I need to remove the ECU so locksmith can program my new key, I only got valet key and it would save me $60 if I remove the ECU myself. Thanx. I have a document that will point out the location of the ECU. You will need to PM your email address so I can send it--too large for this forum. However, it is not necessary to disconnect the ECU to reprogram the key. There was a post recently that detailed the procedure at this link: http://us.lexusownersclub.com/forums/index.php?showtopic=66254 I needed an extra key last year. I ordered a cut key by serial number from a Lexus dealer (they need proof of ownership). I used the attached instructions with no problem what-so-ever to program the remote key. Good luck! Program Lexus Remote Key.pdf Quote Link to comment Share on other sites More sharing options...
tofu Posted September 1, 2010 Author Share Posted September 1, 2010 Does anyone has a picture to show the location of the ECU for 2000 RX300? I need to remove the ECU so locksmith can program my new key, I only got valet key and it would save me $60 if I remove the ECU myself. Thanx. I have a document that will point out the location of the ECU. You will need to PM your email address so I can send it--too large for this forum. However, it is not necessary to disconnect the ECU to reprogram the key. There was a post recently that detailed the procedure at this link: http://us.lexusownersclub.com/forums/index.php?showtopic=66254 I needed an extra key last year. I ordered a cut key by serial number from a Lexus dealer (they need proof of ownership). I used the attached instructions with no problem what-so-ever to program the remote key. Good luck! I just PM you my email. I was told that if I only have valet key then they will need to re-flash the ECU. My car is 2000 RX300. Thank you very much. Quote Link to comment Share on other sites More sharing options...
jinsoo Posted May 2, 2013 Share Posted May 2, 2013 Does anyone has a picture to show the location of the ECU for 2000 RX300? I need to remove the ECU so locksmith can program my new key, I only got valet key and it would save me $60 if I remove the ECU myself. Thanx. I have a document that will point out the location of the ECU. You will need to PM your email address so I can send it--too large for this forum. However, it is not necessary to disconnect the ECU to reprogram the key. There was a post recently that detailed the procedure at this link: http://lowpricekeys.com. I had my RX300 ECU reflashed and higly recommends the service. Quote Link to comment Share on other sites More sharing options...
