  • 4 weeks later...
Hi JJLEV,
I'm keen to know as well as I like the look of the IS factory alloys, can anyone advise whether the IS wheels actually fit on the GS?
Thanks.
They will fit since they have the same bolt pattern and the offsets are OK. The issue is that they are narrower than the stock GS wheels (which are already narrow). The wheel will be inset in the wheel well.
  • 1 month later...
can you get a spacer to counter this?
Spacers will help somewhat. I know people you have put on spacers in the rear with OK results. The fronts, however, cause vibrational issues. I'd recommend against it. Plus, you are still running narrower wheels on a somewhat beefy car.
