Door Will Not Open
D.Bell
I've been having troubles with my driver's side door. It seems as if it is locked, but I cannot unlock it manually or with my key fob. It will not open from the inside or out. Does anyone know how to open the door? Once it is open i am confident that I can open the panel to fix the problem inside. Please let me know if you have run into the same problem and how to fix it. Thanks!
I just got this exact same problem yesterday. In that club lexus thread it doesn't mention how they got the door open which is still a huge problem. My lock seems to also be stuck locked and when you try to unlock it with the key you can feel it putting pressure on the lock mechanism, but it just wont turn to unlcok. Is there a way to unlock it or pop the door open without shreding the door panel?
  • 1 year later...
