2001 Es300 Cabin Filter Replacement
  • 2 months later...
Finally found it and hope this will help others who want to change the cabin air filter too. The filter(s) are under and behind the center console. One would have to pull the carpet on the center console from the driver side. All you have to do is to pull the tab and both (upper and lower) cabin air filters will come out. When putting back the filters you would have to push the upper filter up and then push in the lower filter right underneath the upper filter.
  • 2 months later...
  • 5 months later...
