Spark Plug Wire Thickness
yank30265
Yes 5mm are the norm,you can fit thicker after market leads but you will have to modify/cut/remove some of the clips that route the wires so using the thinner ones makes changing them easier.
On the passenger side make sure you refit the grommet where the lead from the coil passes through the plastic cover.
Good tutorial below.
http://www.lexls.com/tutorials/ignition/sparkplugs.html
