yank30265 Posted July 18, 2010 Posted July 18, 2010 i have 270k on my ls400; it sat in a garage for 4 yrs and i got it and have put 20k on it since then. it is starting to run rough i would like to do the plugs and wires. but cant find them; i removed the wire cover on the driver side and found no plugs; where are the plugs located and how r they changed?; i have a shop manual vol 1 and 2 but Dont see any cut and dry way to remove the wires or plugs
landar Posted July 18, 2010 Posted July 18, 2010 http://www.lexls.com/tutorials/ignition/sparkplugs.html
kuziwk Posted July 20, 2010 Posted July 20, 2010 i have 270k on my ls400; it sat in a garage for 4 yrs and i got it and have put 20k on it since then. it is starting to run rough i would like to do the plugs and wires. but cant find them; i removed the wire cover on the driver side and found no plugs; where are the plugs located and how r they changed?; i have a shop manual vol 1 and 2 but Dont see any cut and dry way to remove the wires or plugs hahaha it took me 2 1/2 hours have fun with that.
yank30265 Posted July 31, 2010 Author Posted July 31, 2010 i have 270k on my ls400; it sat in a garage for 4 yrs and i got it and have put 20k on it since then. it is starting to run rough i would like to do the plugs and wires. but cant find them; i removed the wire cover on the driver side and found no plugs; where are the plugs located and how r they changed?; i have a shop manual vol 1 and 2 but Dont see any cut and dry way to remove the wires or plugs hahaha it took me 2 1/2 hours have fun with that. ill be happy if it only taes 2 1/2 hrs; looks like alot of work
RDM Posted August 2, 2010 Posted August 2, 2010 Replacing the plugs and wires is a 30 minute job max. You guys must be overthinking something.
