'93 Fog Light Replacement
redsully
Yes, yes, I know: the '93 SC300 doesn't have fog lights. They're instead OEM as cornering lights. How cute.
Well, my '93 SC300 DOES have fog lights, thanks to a recent conversion. But now I'm looking to upgrade the lenses... would 1995 SC300 fog lamps fit into the holes where my converted cornering lights currently go?
I think the advantage would be that the real OEM foglamps will spread light in a better pattern. Am I wrong?
From outside it looks identical (IMO). It has a cone shaped cone inside that makes the lights light straight. There should not be any difference from the previous years since they look identical. IMO the driving light on 2nd phase of the SC is not much of lighting because of the location and the shape. I sure can’t tell much difference with on. You may want to go for after market lights which should give brighter and extended lighting.
