Door Speaker Issue
Mike Smith
I have a 2003 Lexus 470LX. The right side front lower door speaker has a flutter in it. The speaker was supposedly replaced about a year ago. Do you have to remove the door panel to access this speaker, or does the speaker cover pop off like home stero speaker. The speaker cover appears to be anchored in 3-4 places put not sealed to the door. I would like to take a look at this speaker myself, if I can do so without causing any damage. Thanks.
  • 4 weeks later...
I have this problem as well, and the dealership charged $300 to replace the speaker, which sounds identical. I doubt they replaced it at all. For now, I've unplugged the the speaker. It requires removing the door panel which is held on with three plastic clips with pop in centers on the sides of the panel, two screws under leather colored plastic plugs, a screw behind the door handle, and 5 or 6 screws along the bottom of the panel in the innermost black stripping. The whole process took about 10 minutes. My truck is a 2001, hope this helps.
