Nakamichi Sound System
MRF
One day the system stops working. It has a sound coming fromthe speakers like a skipping cd. Is the amp shot or the head unit or both? Any help would be appreciated. Maybe it's time to go aftermarket with the whole system? 1995 SC400
It could be blown (rear) speakers, especially if they are still stock. I had this problem and thought is was my amp. I would check/test the rear speakers with a cheap 2inch speaker you can buy at wal-mart. Take the trunk lining down on the passenger side/Cd Unit and locate/disconnect the +/- connections attach the working speaker to the +/- clips and turn on the radio and prey for sound. Here was my DIY
First half to process:
http://us.lexusownersclub.com/forums/index.php?showtopic=36346&hl=rear+speaker+replacement
Second half:
Second half:
Thank you for responding! I took out the CD changer and amp and started looking for a replacement amp on e-bay. Not too many for sale that match the model # on the amp. I will put them back into the car and then try your speaker test. Thanks again.
