Height Setting On Suspension
Hello,
When the 'height' setting on the suspension is activated, how much higher should the front and rear go up? What is the best way to measure, can I measure from the wheel openings to the floor (I know the front opening to the floor is different that the rear).
I'm looking for a way to confirm that it is working as it should.
Thanks,
Hank
:cheers:
OK. over the weekend i took several measurements and found that the front rises about 1 1/4" and the rear about 1/4" when the Height High button is activated. I beleive that this is waaaay to little, but does anyone else have any data or specs on this?
cheers,
:cheers:
Hank
