kuziwk Posted June 21, 2010 Share Posted June 21, 2010 so the trac light always comes on, which goes away when i turn off the car and start it again, however it seems to only do it, or do it more often in hot weather. Is there something i narrow it down to such as the actuator? update... i did the diagnostic and it came up as 19 19 - TRAC motor ON and OFF operation is higher than a predetermined number of times (accumulator pressure leakage what does this mean Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted June 21, 2010 Share Posted June 21, 2010 Read post 7 here: http://www.clublexus.com/forums/ls400/387474-trac-code-19-a.html a small piece of black tape could "resolve" it too ;) Quote Link to comment Share on other sites More sharing options...
kuziwk Posted June 22, 2010 Author Share Posted June 22, 2010 thanks man, ill check my fluid levels as i have not seen any brake fluid leak. I can get a new accumulator does anyone know where its located and how to replace it. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted June 22, 2010 Share Posted June 22, 2010 thanks man, ill check my fluid levels as i have not seen any brake fluid leak. I can get a new accumulator does anyone know where its located and how to replace it. Mine is RHD so I would assume that your's is located on the passenger side at the rear of the engine compartment,there is an L shaped black plastic cover over the pump motor/accumulator to remove simply pull it upwards. Quote Link to comment Share on other sites More sharing options...
kuziwk Posted June 22, 2010 Author Share Posted June 22, 2010 thanks man, ill check my fluid levels as i have not seen any brake fluid leak. I can get a new accumulator does anyone know where its located and how to replace it. Mine is RHD so I would assume that your's is located on the passenger side at the rear of the engine compartment,there is an L shaped black plastic cover over the pump motor/accumulator to remove simply pull it upwards. will brake fluid leak out? anything i should know? Im pretty sure its the accumulator as my brake fluid reservoir is just under the max fill line. Quote Link to comment Share on other sites More sharing options...
