drewzer Posted June 18, 2010 Share Posted June 18, 2010 Can the oil pan on my 1999 Rx-300 2WD be removed while the engine is in the car? I likely ran out of oil and got the oil light, but engine may be cooked, as it knocks and barely starts. Wondering if by removing oil pan, I can examine if bearing materials were transferred onto the crank shaft journals. My uncle says this is a long shot, but if the oil pan is easy for a mechanic to remove, I may instruct him to do so. Any help is appreciated. Thanks! -Drew Quote Link to comment Share on other sites More sharing options...
Jeffstpetebeach Posted June 18, 2010 Share Posted June 18, 2010 Yes the oil pan can be romoved without the engine having to be removed. The bolts I believe are 10MM about 12 or more. I have a PDF file on the engine if you need it, which sounds like you might. Just Pm me and I'll get it to you. Good luck Quote Link to comment Share on other sites More sharing options...
